Dental System software interface displayed
Implant Studio — Software updates
3Shape Implant Studio 2024.1
3Shape Implant Studio is the smoothest and most automated version yet. A surgical guide outline is created based on artificial intelligence, making guide creation a breeze. CT scan handling has been rethought using a patented cropping for unparalleled clarity. Moreover, the surgical guide output is now handled by 3Shape Produce. Get an overview of all the latest features added in Implant Studio in the What’s new document. Download it here.
NEW AI guide design
Implant Studio 2024.1 is using AI technology to analyze the jaw and create the outline for a full-coverage surgical guide, which the software will then automatically build without the need for user input. It is easy to edit the guide outline or even start over if another design is desired.
NEW Mandibular/Maxillary cropping
A patented technology is used to precisely crop the (CB)CT scan for the jaw to be worked on, providing clarity , and remove unwanted objects from view in the 3D scene including teeth that have been extracted after the scan was performed. This provides unique clarity when planning implant placements.
NEW Redesigned cropping step and CBCT handling
The cropping step has received a makeover and is now in 3D. The region of interest can easily be adjusted either in the 3D-scene or by dragging or scaling the boxes in the 2D windows. The cropped-away regions are still visible, making it easy to detect if some important anatomical detail have been cropped away by mistake.
IMPROVED X-guide integration
When planning for the dynamic surgery solution, X-Guide by X-nav technology, the designed virtual crowns will now be transferred along with the plan, visualizing the intended outcome while performing surgery. In this way, more insights are available when taking clinical decisions.
Important notes
Patches
 Release Date  Comments
Implant Studio 2024.1 February 2024 Full release
Useful links
Implant Studio on 3Shape Community
PREVIOUS UPDATES
KEEP LEARNING WITH 3SHAPE COMMUNITY
Library of tutorials:
  • 3Shape Implant Studio Fundamentals: Implant studio is an open flexible system, which means you can choose to plan your implant positions, design your surgical guides before producing them or you can choose to only perform one of those steps. In this section we will show you the whole workflow and you can choose which parts to do yourself.
  • Setup and administration: Learn about some basic steps that should be taken to in order to work with the software.
  • Treatments: From single implants to full edentulous rehabilitations, Implant Studio enables you to plan and design a wide range of treatments, in-house, by collaborating with a laboratory, or using a Design service.
NEW 3Shape Produce
Implant Studio 2024 works with 3Shape Produce, easing the process of producing surgical guides and screw-retained crowns
The machine choice from the software is transferred to the Produce step, that allow for seamless integration and optimized production on a wide range of milling machines and printers!
Learn more.
ASIGA
Formlabs
Rapid Shape
Ivoclar
VHF
DGShape
SprintRay
Dental System updates
TRIOS Design Studio updates
Improvements and changes in the TRIOS Design Studio software.
Model Maker updates
Ortho System updates
